So, I have the following,
1 x 260w solar panel (Not currently connected)
1 x solar charge controller (Not currently connected)
1 x 102Ah deep cycle battery (12v)
1 x 300w pure sinewave inverter with built in charger
Required output +-50W - 60w
With that being said I currently have the setup as follows,
Main grid -> Inverter (Connected to battery) -> Fish tank (Running through inverter).
I want to do the following (Due to extended power cuts in my area),
Main grid ->Inverter (Connected to battery, while at the same time connecting solar panel and charge controller to battery) -> Fish tank (Running through inverter).
The reason behind this is my battery lasts about 24 hours, however the power cuts have been longer than this, therefore I would like the solar panel to charge battery, therefore if the main grid cuts out and the inverter starts using the battery power, then atleast the battery will continue charging from the solar panel.
With that being said my concerns are regarding having the main grid charging the battery at the same time as the solar panel. Is this possible?
