LandyMan
Yeah, was just an example that it is possibleThere is no grid in this scenario.
load dependant a 5kw inverter means 48v brickmuch better idea. get the panels you need. Inverter size and 1 to 2 lithium batteries. mount them on a trailer and drag it where you need power for the day.
many will start up even without gridThere is no grid in this scenario.
Yes, those are called "grid-tied" installations. Most of the world is like this. Only SA do we use batteries.Yeah, was just an example that it is possible
if you use grid-tied you can only use the solar power if eskom is there (no shedding)Yes, those are called "grid-tied" installations. Most of the world is like this. Only SA do we use batteries.
I was talking about the rest of the world who doesn't have the problem of the grid falling over all the time so they use the grid as a "battery". We need real batteries.if you use grid-tied you can only use the solar power if eskom is there (no shedding)
while if you get a hybrid, you can have backup power during the day direct from sun no battery needed even if eskom is gone, you only sacrifice night time backup without the battery
