Solar string configurations on opensolar.com
abudabi
JHB
I've been playing around with it and need to understand why this influences power generation as seen below. Is a watt not a watt ? There's about a 150 watt difference in the 2 setups. Incidentally; opensolar's best string configuration spat out the 1st option.
I thought maybe it was due to the AC/DC ratio differences, but redoing it with equal ratios still shows a difference. Am I just being thick and missing something obvious? Is it maybe because of the inverter efficiency "sweetspot"? Or a glitchy site calc?
If you are selecting the same panel and location in all 3 examples, then it's definitely a bad calculation on the site.
