Truth is solar uses batteries and batteries are expensive and no matter the battery it will cycle and once it cycles enough it will lose capacity and it will not last nearly as long BUT it was still a very heavy investment for something that will become a very large paperweight in the end of the day.
Good day Everybody,
It seems like 2022 is about realizations and facts rather then promises and snake oil.
About 7 years ago I got myself the cheapest and nastiest solar system I could find. Most of it came from local shops and so on and nothing fancy. My batteries was a couple of car batteries because deeps-cycle batteries was scary expensive at the time. I wanted Gel batteries but even those wasn't cost effective.
So did it work? Well for a time it actually did. My system was a 12Volt system and I doubled the amps with a parallel setup. I was so sure the thing would catch fire i mounted it outside and ran an power extension cord to my home. Also car batteries produces fumes
and because of that I got a piece of rubber and kept them in a cool dark place that was very well ventilated.
And it worked! No fire, no brimstone and it just did what it was suppose to do. I was able to keep my basics running and took care not to overload the system. I had lights, I had the ability to charge my devices and from time to time i even ran a 12 volt refrigerator on the batteries. It just worked.
The cheap solar panels burned out fast and one couldn't survive a hail storm but it worked. So i mounted my solar panels to a custom frame and was able to detach and store the panels whenever the weather turned a bit bad. Also second time around my panels didn't get damage or burned out.
Now to be clear my system is stand alone and is in no way connected to the house as stated before I got an extension cord and used it like that till this day.
I had to replace my batteries twice in the 7 years but considering how much of a hammering they got from being constantly charged and discharged I expected as much.
All this said I will not spend R40k on it or R60k on it or even a R100k. This one client of ours had a 5kw system and it worked out to about R20k per 1Kw and that is a lot of money. My tiny little 800Watt inverter cost me about R900 and the panels i can't count because i had to buy them twice. But in total if i spend R5k on it, it would be a lot.
But i must mention this, invest in a good fluke. One that can give you Hz reading and check that it the inverter runs at 50Hz AND you get 230 Volts.
But if you have to keep the bigger stuff going I would invest in a good generator. They are a lot cheaper and can push a lot more power on demand then what solar does. I wouldn't spend those insane numbers on solar.
cheers
Not as fancy as yoursView attachment 1230556
I dont think I need to say anything else. Spent around R100k on this system incl the 2nd phase of my install
If you buy " cheap and nasty" and install the panel indoors I guess you will have no output above 25 Celsius.I was told even the best solar panels can't generate a lot of power in cloudy weather. It is documented between 10% to 25% in cloudy conditions depending on model, location and temperature as ironically even solar panels "depending on model and make" has a peak of 25 Celsius and at that point they may produce less or no power.
