I'm staying at a friend's house this weekend and want to use my own DStv decoder. It's a HD PVR 2P decoder which I normally use successfully with just one cable. There are normally some issues due to using one cable (e.g. the programming guide doesn't work and I don't actually use the PVR functionality), but other than that, all the channels normally work. However, when I plugged it in here, only some of the channels work, others tell me to check the set top box. Any ideas on fixing this? I've done the usual basic stuff like resetting and rescanning, but no luck. Signal strength shows up as 98% on the channels that work and 0% on the ones that don't.
The house does have a DStv connection, but it's on a cheaper package with an SD decoder. I'd settle for using my smart card in the SD decoder, but that doesn't seem to be possible according to the call centre. The DStv site talks about holiday home support for this, but if I try and register the SD decoder here it tells me it can't be linked, presumably because it's related to another subscription.
