Some excel help
Razor88
Hi guys.
I'm not very familiar with excel, so if this is trivial, please forgive me.
I have an excel column like this in Column A:
Bread
Milk
Cheese
Now I want to copy the contents of A to Column D but I want it to skip a line after each entry like this:
Bread
Milk
Cheese
Is there a way to do this using a cell formula?
No, don't think so.
Why would you want to do that though?
No, don't think so.
I'm making shelf labels to help someone out.
So I wanted it to map the description from A1 to D1, then the price from B1 to D2 etc, so that it looks like this:
Blue Ribbon White
R12.50
So that they can just highlight the D column and print it.
I'm no expert but wouldn't transpose work?
Doesn't OP have a column of names and a column of prices?
Hi guys.
I thought that you wanted everything in column A to be copied to column D.
However, it seems like you want to transpose everything in column A.
Or what?
Or what?
Hi. I planned to copy everything from A(description) to D and skip a row so that I could put Price (B) in the empty row. Something like this:
Turns out that transpose works for my purposes though, so I'll probably use that.
This formula might do the trick for you:
=IF(MOD(ROW(),2)=0,INDIRECT("A"&(ROW()/2)),"")
Change the "A" in the INDIRECT function with whatever column your base values are in.
Edit:
This one is more like it:
=IF(MOD(ROW(),2)=0,INDIRECT("A"&(ROW()/2)), IF((ROW() -1) > 0,INDIRECT("B"&((ROW()-1)/2)),""))
And will include your prices underneath :D
Edit:
This is literally perfect, thanks :)
