Some pretty basic SQL query help
Brawler
Hi. I haven't done SQL in a damn long time. I'd appreciate some help with this rather weird query that I need to run. I've made this one up but the logic is the same.
Bear with me:
2x tables:
Customer(custId, name, surname, etc)
Order(orderId, custId, numberOfOrder)
Clarity on orderId and numberOfOrder: OrderID is just a unique number for each row (PK) and numberOfOrder is the number of the order per customer, i.e. the first order will be 1, the second 2 and so forth.
Obviously each customer can have many orders.
What I want the query to do:
I want to select all of the customers names and surnames who do not have a NumberOfOrder of 1.
I have joined the tables and all and I can easily search for those that have an order number of 1 and then filter them out from the original dataset to get the values I am looking for but I am hoping there is an easier way to do this in SQL?
SELECT Customer.name, Customer.surname, Orders.numberOfOrder FROM Customer
JOIN Orders ON
Customer.custID = Orders.custID
WHERE Orders.numberOfOrder <> 1
You shouldn't use the table name "Order". It's a keyword.
JOIN Orders ON
If there are no records at all for a customer in the order table will this be picked up? If not, then maybe some version of this plus an outer join of sorts.
SELECT Customer.custID, Customer.name, Customer.surname
FROM Customer
INNER JOIN Orders
ON Customer.custID = Orders.custID
GROUP BY Customer.custID, Customer.name, Customer.surname
Just left join to ensure you get all customers regardless of having orders or not.
If you got duplicate customers then bad initial design. Should have a unique index on customer name and surname preventing duplicates getting in in the first place.
Can't understand why grouping to identify duplicates even came up to be honest.
Of course, and add the group by clause to eliminate duplicates of people, if that is what you require.
Since the order table have multiples of the same custID the grouping is to eliminate the same results appearing in the output not to eliminate duplicates of different people with the same name
Indexing on name and surname? Now who is talking bad design. You do know people can have the same name and surname right? Like at my work place we got two people identical name and surname so i guess one of them cant order anything :wtf:.
He will need to think of a better way to isolate duplicate clients, or actually not at all. I mean i've registered three times on amazon with the exact same details except for my email. So use an email has a unique identifier per customer.
Was in argument to grouping by name/surname to handle duplicate customers. Read first - then argue.
I even quoted it. How did you miss that?
Left join, yes
Unique constraint on name/surname, no
Interesting to see the group by. I would have used "distinct". Does the group by offer a performance gain?
Whether you where responding to something of that nature or not is immaterial, the advice you put forward was flawed. And if you read in the actual group by the customer id would have been there so in essence it would have been unique unless the post was edited after the fact, which it seems so. Even then still your advice was flawed.
Okay.
Left join, yes
Distinct will be faster if you have indexes, where as group by's will suffer performance if its having to cluster fields together.
Indexes on names can be very unreliable. Some people have strange spellings and the user might spell it incorrectly or it may have been spelled incorrectly when first captured. The solution to this is have a column which stores the SOUNDEX version of the last name. The search is on this column. Any customer search should always list the customers with the matching names and then include date of birth and address as well. Customer services users should have been trained to verify the identity by asking for the customers date if birth and address. It's then easy to identify the correct record. The chances of someone living at the same address with the same name, same gender and same date of birth are very remote.
Don't try unique indexes on names. It's a world of pain. Duplicate customer records are always an issue. Proper training of your customer services helps
Bear with me:
2x tables:
Clarity on orderId and numberOfOrder: OrderID is just a unique number for each row (PK) and numberOfOrder is the number of the order per customer, i.e. the first order will be 1, the second 2 and so forth [1].
I want to select all of the customers names and surnames who do not have a NumberOfOrder of 1 [2].
This is confusing: as per [1] above, each customer's first order will have a numberOfOrder value of 1, second order will have a numberOfOrder value of 2, and so on. However, as per [2] you're looking for all customers that don't have a numberOfOrder of 1. These then can only be customer that have no orders at all!
However, if we're only looking for customers that have placed more than one order, then, apart from duplicates, this will work fine:
JOIN Orders ON
But that doesn't include customers that have no orders. To include them, and simultaneously remove duplicates, try:
Code:
select c.custid, c.name, c.surname
from Customers c
where not exists (select 1 from "Order" o.custid = c.custid and o.numberOfOrder <> 1)
What is actually the business information you want out of this?
Methinks he has been tasked to identify bad data. Maintenance instead of business code.
Correct.
It's bad data. I am trying to find all customers that have a missing first order.
