Some Warlock help
DjStyles
Cape Town, South Africa.
I recently started playing my locke again after it being a farming toon for a long time.
I have dual spec destro & demo. What i need is some assistance in getting this things DPS up to a respectable level.
I ran a cr@p load of HC's the past week and got 4 x T9 gear items, as well as the 75 emblem of triumph head pieace (forget the name now).
Can someone pls advise me on things like rotation, glyphs and pretty much anything else to help get tmy dps up.
Oh, toons name is hustlerxalt on quel'thas
Demo spec:
Glyph: Metamorphasis, Felguard and Life Tap
Meta: Chaotic - 21 Crit + 3% Crit Dmg (need 2 blues)
Gem:
For Hitcap (14% or with suppression 11%): Rigid/Veiled
Then: Runed (Red), Reckless (yellow), Purified (blue)
Rotation (single target):
Metamorphasis (for more dps; charge, shadowflame & activate immolate aura), Demonic Impact, CoA if high hitpoints, else CoE, Corruption, Immolate, shadow bolt, incinerate when buff up.
At 35%: (try save meta for this) Soul Fire2x , SBx1 - keep dots up
If 3 or more mobs; seed of corruption.
Last tip: let your dot run out before reapplying.
Don't be lazy and do some research...Having your char on lvl80 and not knowing anything about it is a bit of a fail. :S
It's not me being lazy. I asked for some advise, as the locke's seems to change with just about every patch. I played demo spec all the way to 80, but then was told that Destro is the spec to be for high DPS. Hence me asking for ADVISE.
