Sonicwall Assistance Required
The_Librarian
Another MyBB
Super Moderator
Dark room in Adventure. Grues abound.
Hi Guys
We have three sites, all connected with Vodacom wireless for connectivity.
The Voda firewall maintains a secure VPN tunnel between the three sites.
Then we have a Sonicwall router behind that firewall.
Now we lost one Sonicwall router on one of the sites.
Everything works (once we plugged in a new Sonicwall and configured it).
However, incoming SSH from two of the sites to the third one no longer works, and I figured out we need to add a portforwarding rule on the specific Sonicwall to allow SSH to go to the correct IP.
We also need to add a sonicwall VPN client username and password as well.
I had a shufty, but it seems to be a bit complicated as you need to do a couple of initial steps beforehand... :confused: (so different from using a Smoothwall...)
Do we have a Sonicwall guru to assist with these two steps?
Will appreciate it very much
Cheers
Ook
I've setup a couple of those SonicWalls. Actually quite like them. Pop me a DM if you haven't come right with this yet.
