Pieter2008
Hi, I want to connect my 'Sonoff SV Inching /Self-Locking WiFi Wireless Switch 5V 24V' to the automated garage door unit.
I've done this before with the motor gate, but the labels (12v+-,COM,NO) matched up to the sonoff 12v unit, so it was quite straight forward.
Unfortunately, I am not sure where the connections go on the garage unit, seeing as the labels differ.
I see there is currently a red and black wire running to the alarm unit from PB/GND.
I am also not sure, if the 24v takes up 2 holes, and if the last hole is just not labeled/used.
Could anyone advise as to how to make the connections please?
Thank you
Thank you
