SONOFF Load Shedding Detector Kit - MINI R3
jezzad
Purchased a SONOFF Load Shedding Detector Kit from GeeWiz - https://www.geewiz.co.za/sonoff-pro...-shedding-detector-kit-with-instructions.html
Image and instructions for install are for a Sonoff Mini R2 with S1 and S2 connections.
Actual product that was delivered had a Sonoff Mini R3 in the box with two L and two N connections.
Electrician is here trying to install it and is a little concerned that they are not the same devices and are missing contacts.
Anyone install one and run into similar issues?
Looks like you need two common wires which the R3 seems to not have. I think the Mini R3 is supposed to come with a S-MATE which gives you the common lines but is powered by a button battery.
Contacted GeeWiz and they sent a replacement Sonoff Mini R2 seems like a packaging mistake.
