Bionic
Hey All
Ok,so i think i've decided on my 5.1 setup but wanted to get confirmation from the team.I have my XBOX,LCD(1HDMI,No optical),DSTV(SD) and want to purchase the Sony HT STR500.I can get it for R4600.Seems a bargain.
Will this be fine.It has 3 HDMI in and 1 Out,2 Optical in,DTS.So ideally i would connect my XBOX to the HDMI port on the reciever and then HDMI out to the LCD.Do i still need optical to get sound(5.1).
Check the specs ..Is it worth it?
Receiver:
Amp. Channel 5ch
Type Analog
Digital Signal Processing (DSP) Sharc
Speaker Selector A
Speaker Terminal Front(Screw)/Others(Push)
8Ohms 20-20kHz 85W + 85W
(8Ohms 20-20kHz) THD 0.09%
4 Ohm/8 Ohm Switching No (8 Ohm only)
Analog Direct Yes
Connectivity:
A/V In/Out (S-Video In/Out): Including Front A/V 2/1 (0/0) + V1/0
Audio In / Out / TV CEC 2 / 0 / No
Component Video In/Out (HD Pass through) 2/1
HDMI In/Out 3/1 (Switcher type)
Optical In/Out: Including Front In 2/0/No
Coaxial In/Out 1/0
Digital Media Port 1 (No OSD Support)
Pre Out SW x1
Sound Decoding Format / Sound Field:
DTS / DTS 96/24 / DTS NEO:6 Yes / - / -
Dolby Digital / Dolby Digital EX Yes / -
Dolby Prologic / II / IIx Yes / Yes / -
Portable Audio Enhancer Yes
Dolby Dual Mono Yes
Cinema Studio EX A/B/C mode Yes
Sound Field Progam Movie / Music / A.F.D / 2ch / Headphone 3 / 4 / 5 / 2 / 2
HDMI Quality & Video Details:
HDMI Video Handling 1080p
1080/24p Yes
Tuner:
Preset Channel (FM/AM) TTL60 (30/30)
Station Name Yes
Auto Tuning Yes
Direct Tuning Yes(RM)
Other Feature:
Auto Room Tuning DCAC (BRONZE)
Auto Room Tuning Mic (Stereo/Mono) MONO
Subwoofer Cross over 13 points (40-160Hz)
A/V SYNC Yes (fixed)
Sleep Timer Yes
Dimension (WxHxD) 430 x 157.5 x 322 mm
Weight 7.4kg
Thanks in advance
Receiver:
Amp. Channel 5ch
Type Analog
Speaker Selector A
Analog Direct Yes
Connectivity:
Coaxial In/Out 1/0
Pre Out SW x1
Dolby Dual Mono Yes
1080/24p Yes
Tuner:
Station Name Yes
Auto Tuning Yes
Other Feature:
Sleep Timer Yes
Weight 7.4kg
Thanks in advance
