Sony VPL-SW536C projector issues
The_Unbeliever
Nkaaaaandla
Hi
We purchased a new Sony VPL-SW536C projector.
It works nicely, especially when giving presentations via wifi.
However, I can't get the Interactive Presentation Utility 2 program to work as intended. (whiteboard mode).
The projector is connected to the laptop with the supplied USB cable. Laptop do pick up the projector.
When I start the IPU2 program, it does not transfer the laptop's image over to the projector, instead the IPU2 remains on the laptop's screen, no matter what I do. I have tried two other laptops, but it did not made a difference, the IPU2 program does not transfer the image over to the projector at all.
Reading the manual does not shed any light on this matter. It is, according to the manual, a simple matter of installing the software, and connecting the projector up to the laptop via the supplied USB cable, and change the input from network to USB. (Type B is connected to the laptop, Type A is the standard USB slot for your USB flash drive).
If anybody can help us, it'll be appreciated.
I've had a similar problem with an Epson projector. I downloaded a new copy of the software and all was well.
Maybe see if Sony has it on their site and try a new version?
