sound advice please.
upup
currently offline
My wife sits about 40 meters from the tv. She needs headphones, wiresless or wired to listen to the tv. There is no power plug where she sits, What headphone would you suggest, if wireless the batteries should last long.
Are you sure it's 40 metres..???
40m? How big is the TV?
lol what xD tell her to stop watching the neighbours tv you tight arse
JBL anc wireless headphones, it can normally be connected to the TV if it has bluetooth. they work great.
Sorry 4 meters direct, Tv does not have bluetooth. I am planning to connect to av out on the explora, Tv currently run on HDMI. TV only have av in .
what tv?
and just say you want to watch porn without anyone hearing...we won't judge you
Then an RF wireless headphones would be a good choice..
You can also use a Bluetooth transmitter with Bluetooth headphones.. though, mileage may vary greatly here, between the transmitter, battery life and quality of Bluetooth headphones..
Buy a Mibox and use Bluetooth 5.0 earphones.
But as far as I know, you can only pair one set of earphones, so no good for families.
Since there’s hdmi, the tv isn’t THAT old, and should probably have a stereo/headphone out?
If so, get this and buy any wired headphones you wish, as these are 5m and can be run subtly from the tv to where the Mrs sits:
3.5mm Male to 3.5mm Female Stereo 5M Cable Aux Extension - Takealot R146.
I have one of those tv’s In my daughters room as well, no sound outputs at all.
Had to use android box outputs for sound via sound bar
