Sound help
sbu22
Hi there, I just finished building a bar and restaurant. I need advice on hooking up a sound setup.
Is this something I can diy or is going the route of professional more advisable? Another issue is I'm from a 1 horse town; Howick, so getting a professional can also be an issue.
To the sound fundis, please help.
The space I need to cover indoor is 20m X 14m. I also have an outdoor setting which is 28X10.
Any ideas would tbe appreciated
I'm no fundi but you can definitely DIY, it all depends on what your needs are like will you be needing sound from DSTV for sport and at night for a dance floor/DJ etc?
I think you can easily get away with few JBL satellites/amp/iPod dock on the cheap.
If you need some pro help, PM me your details and il get someone near Howick to scope it out for you.
Thanks for the reply bud, will definitely send u a pm.
Glad to hear that Howick's horse is alive. I thought that it had died.
Hahahaha luckily it was female it had a fawn before it died :). The saga continues
Any ideas, where I can get the jbl satellite speakers and amp. Saw the onkyo and jamo set from dionwired, can something like with like additional speakers or? I don't wanna spend a fortune on sound, cos normally it would be for sports and those DJ nights.
