kang
I've just hooked up my LCD to my HDPVR and everything is fine except for the sound on channels broadcast in Dolby Digital 5.1.
When I'm on MM1,MM2, or the HD channel the sound blasts out of the tv and nothing you do on the DSTV remote will change it. You have to reduce the volume with the tv remote which is usually hidden under the couch, with all the loose change. All the other channels work fine.
I have changed the settings on the decoder now to manually select surround sound and this has solved the problem but I shouldn't have to do that. Its supposed to just work!
Does anyone else have this small but annoying problem?
