SPB Mobile shell 3D - help
marine1
A black hole in the universe - JHB
Need some help please.
Installed it on my Xoom, now when I click on the home screen, the interface is now gone and I cannot find the program or how to re activate it. Its back to the stock standard home screen???
:confused:
Restart your Xoom and when you unlock your sim, you should get a combo box asking you if you want to complete the action with Motoblur or SPB Shell.
Select SPB Shell and see if things return to normal.
Otherwise, remove and install it again.
Jeeesh say what? unlcok my sim? Not sure what you mean.
Every time I re install its fine, then the minute I select the hoe screen it vanishes and the actual program has no icon anywhere.
When you boot up your tablet and enter your pin number for your sim. :P
Try installing Home Switcher from the market. It allows you to set the default home screen. Worked on my Galaxy Tab.
Sent from my GT-P7500 using Tapatalk
What's up with all these old toppies hanging out on MyBB with their tablets? :wtf:
Tried that too, it like its missing
On Eee Pad all I did was start it the 1st time and was prompted if I want this as the default action for when I press the Home button. Now when I press home it opens it up.
What version are you running?
I had this issue with a "free" version of SBP Shell on my phone.. where it would eventually lose it's place as the launcher, and there was no way to bring it back.. But the paid version works fine. It might have been a bug in the older .apk that I found.
Just checked the What's New section an that was an issue that was addressed in an update some time ago.
You should be on 1.5.3 at least to make this a none issue.
Sent from my Transformer TF101 using Tapatalk
Did you pay for it, I remember I downloaded an "unofficial" copy to test before i actually bought it, lasted 15min before it checked the market, invalidated the license and uninstalled itself.
Def well worth the R115 I paid for it though, will put it back up when I upgrade, Nexus S with SPB Shell does not gel well, not enough ram.
