Special router for fibre?
mintydroid
Looking at buying an additional router which may or may not be used with fibre depending on future needs and was wondering if a special router is needed for fibre? I have been Googling for a clear answer but haven't found anything conclusive.
You need something with an Ethernet WAN port, like any standard non-adsl router.
You do get routers with both DSL and Ethernet WAN ports.
You need something that can take an sfp.
unlikely. Most fibre deployments use a fibre-to-ethernet gateway these days. The sfp is normally in this gateway, and the gateway installed by the fibre contractor. so your router will get a CATx ethernet feed.
This is for FTTH of course, business deployments would be different, but in a business deployment the ISP should provide the router.
My current router supports WAN so I'm safe whichever way I choose. Thanks guys.
Our FTTH deployments include a CPE that accepts an SFP module.
