Hi
I recently moved to a new house and had my ADSL line tranferred as well. A Telkom technician came out, moved the phone jack to where I wanted it, and installed a ADSL filter. He tested with a connecting cable that he had from the socket to my router, the blinking ADSL light on my router became static after a few seconds, indicating that a connection has been established. The Telkom technician left with his connecting cable stating that that was his only cable, and he couldn't spare it. He advised that we buy a cable from a computer shop.
So I found a telephone extention cable somewhere in a box, and used that. This did not work, the ADSL light on the router just keeps on flashing. So yesterday I went out and bought a 2m Ellies telephone extension cable from builders warehoure to hook the router up to the socket. Now here is the problem, it does not seem to connect/sync as well, the ADSL light on the router just keeps on flashing, it never goes static. When I go onto the router's web interface, the status says "telephone cable unplugged". Is there a difference between an telephone extension cable and a "socket to ADSL router" cable?
Any help will be appreciated.
