specific gateway selection for applications.
Necuno
Court Jester
anyone of a software like proxifier for example where i can select an application have it go via gateway A or B on a network. way back in the day this was possible via firewall (can't remember whos), but now that feature of being able to setup routing directly in a firewall as a rule for certain applications to use certain gateways are missing.
however this is currently been done via dos prompt and fixing up the routing table manually.
