AmazeBalls
- Jul 13, 2013
Got a few a few of these around the house. Was wondering if it’s as simple as swopping out the controller to the likes of a Tuya thermostat
perfect thanks. which honeywell ones did you replace them withyes, I got a honeywell one, they said it will last forever.
Home Assistant.mine florr is 2000 watt, so you must make sure that controller got a good switch to handle the amps.
What is HA.
You should ask the installers for the exact specs of the installationI’m thinking about using Sonoff POWr2 switches to control my floors - i.e leave their thermostats but use the Sonoff as a timer via HomeAssistant. Now you have me concerned that the current may be too high?
New Sonoff POW's are available that can handle 25A.I’m thinking about using Sonoff POWr2 switches to control my floors - i.e leave their thermostats but use the Sonoff as a timer via HomeAssistant. Now you have me concerned that the current may be too high?
