Speed increase from router
Lawnchairman
Gauteng
I know its the speed of the line for your ADSL connection that determines the speed of data into your pc. The question is would there be a significant increase in speed if you use a gigabit router to a gigabit nic on your pc or is this just to low a speed that you would never notice it?:whistle:
Unless you get a 100mb line you wont notice a difference. Even then you'd need an ssd.
if you are streaming data across a network , then it would be useful.
