Speed Test Results
b1nary
Perhaps someone here can shed some light on something I have tried to figure out for a while now
When doing Speedtests on Various ISP's with High speed connections I have noticed the following phenomenon:
Using Speedtest.net Local tests will show the correct speed lets say on a 100Mb fibre it will come up as 90Mb download
however it will show for the sake of argument 5Mb international download.
Using Iperf3 a international test will show the same low result, if I however use a multi-threaded test the Speed will go up
till it meets the correct amount as per the ISP's contention ratio.
Can anyone explain this behavior ?
Packet loss causes low TCP window sizes, and retransmits take ages due to latency. Therefore, throughput of a single stream is severely limited. Multiple streams makes up for this in part.
MTU settings on your router/modem?
To Be honest I'm not sure But this I have seen this at home on a 20Mb setup and work with 100Mb unfortunately
I don't have access to the Routers in question as they are managed by the ISP and connected directly to my Untangled Firewall
which I can mess with.
Edit: read up regarding MTU
running it at 1492 gives me Packet needs to be fragmented but DF set, 1400 to 1460 works fine.
Remember the days when local servers cached everything? Then if you refreshed a page it took forever.
The "pipe" leaving the country is probably congested.
