speed test
It said share speed test ...so I did...but now it asks me to post..OK so I have posted !
Still don't know if my speed test is acceptable or not.:wtf:
In the thread in which you posted these results ..
Speed test
Download Speed: 294 kbps (36.8 KB/sec transfer rate)
Upload Speed: 196 kbps (24.5 KB/sec transfer rate)
Latency: 252 ms
06 February 2014 05:15:55 PM:
confused:
does this mean anything?
.. you were asked what you line speed was.
In other words, are you on a 2Mbps or 4Mbps ADSL line?
That way, you can be advised if the results are good or bad.
(as a guide, if you're on 2Mbps, then your results are good, apart from the latency figure, but if on 4Mpbs then not so, on Download speed).
By the way, when you do a speedtest, if you want to post the image of it, then just copy & paste the link given on the page by speedtest.net into your MyBB post.
Ummm, those are 384kbs speeds like what the slowest ADSL was before those lines were upgraded to 512kbps then 1mbps and now 2mbps.
Remember your bits and bytes.
There are 8 bits (b) in a byte (B) therefore a 2 mega bit per second (mbps) line is 2048bits divide 8 = 256kiloBYTES (kB) minus line overhead and should be around 200kB.
