Soprono
- Nov 18, 2009
This basically checks a whole bunch of DNS addys and compairs for the fastest ones out there, then notifies you if its faster, if it is it will help your 360 connection slightly. the download link is below, and the program automatically adds your dns and does ping tests and what not to the other addys, hope this can help.
1. Open it then click start.
2. Give it a few, when done it will pop up and tell you if your eligible for a speed boost.
3.Once its finished if you see a screen popping up saying that Their DNS is faster than yours.
4. Now, use those DNS on the side for Xbox. To do that, go to network settings, click on DNS and change it there.
Windows: http://tinyurl.com/39e3tuf
Mac: http://tinyurl.com/2bqxx3c
