I drove the N2 from PE to Cape Town a few weeks back. There are a number of temporary speed limit signs on the N2 (sometimes from 120 down to as low as 40) where the road works are either completed, or not currently happening and no workers in sight. Sometimes there are road works with a temporary speed limits without a derestriction sign at the end of the works, and many KM until there is another 120 limit indicated.
The law says you have to keep doing the same maximum speed until you see a sign indicating otherwise, but from my experience, not many other drivers are adhering to the last displayed limit in these cases. It's also frustrating doing 40/60 on a road where 120 is the usual limit, with no apparent reason why it should be lower.
So, what do you do when you encounter the above situation?
