Speedtest Afrihost Fibre Packages
jobuskotze
I'm looking in changing to one of Afrihost's Fibre packages but unsure which provides the best latency internationally.
They have:
Home Uncapped
Premium Uncapped
Priority Uncapped
Capped
Currently on Telkom LTE Uncapped I always get 180-200ms internationally, so if that is the norm on the above packages I certainly would change. Can anybody with Afrihost Fibre confirm if it is so?
I doubt whether you will get better than that on any consumer-grade connection unless you are prepared to pay R12,000+ per month for 2Mb low-latency international.
That is not bad at all on LTE
500Mb fibre line, ping to EU:
c:\>ping ping.eu
Pinging ping.eu [88.198.46.60] with 32 bytes of data:
Reply from 88.198.46.60: bytes=32 time=168ms TTL=51
To USA:
Pinging 198.7.59.119 with 32 bytes of data:
Reply from 198.7.59.119: bytes=32 time=219ms TTL=48
Reply from 198.7.59.119: bytes=32 time=218ms TTL=48
