SQL 2005, indexes on WHERE clause.
xrapidx
quick question - trying to explain something to someone, and can't quite recall exactly.
If I create THREE different indexes on three different columns on a SQL Table as follows:
[Column A] idx_a
[Column B] idx_b
[Column c] idx_c
And then run the following query:
SELECT *
FROM
WHERE [Column A] = 1
AND [Column B] = 1
AND [Column C] = 1
Only one of the indexes created will be used in that query? Is that correct?!
Not near SQL to check - and google isn't returning what I want.
AFAIK that is correct.
The SQL query optimizer will only use one index per query, hopefully it'll pick the best one.
I'm not sure this is entirely correct. It seems to depend entirely on the optimizer. In addition, the cardinality of the data plays a big part in the query plan.
Google 'Index Intersection'.
I realise the following info is dated, but it may still be pertinent in current SQL Server releases:
http://technet.microsoft.com/en-us/library/dd316335.aspx
However, both SQL Server 7.0 and SQL Server 2000 support index-intersection joins, which should provide most of the benefits of bitmap indexes.
So for example, if you have a large table with a Gender column (2 values) and a StateId column (50 values), you can create individual indexes on each of these columns. If then you have a query that says WHERE Gender = 'F' and StateID = 'WA' , SQLServer is capable of using both indexes and intersecting the matching rows from each (using a join) to find the qualifying rows.
