SQL Help ?!?!
Pho3nix
The Legend
On the toilet
Hi guys,
Need help with a query on SQL. Need to import all the rows from Column B into Column A, aslong as they aren't already there. Tried UPDATE but it is not working. Any pointers?
Just started learning..
Update tablename set columna=columnb where culumna<>columnb
Sent from my GT-P7500 using MyBroadband Android App
Tried it but still no luck :(, and have 500 entries to put in...really not looking forward to the Insert Method :(
Evern tried
Update tablename set columna=columnb where culumna!=columnb
Running the queries direct from SQL Server management Studio so I'm pretty sure I'm connected to the database :?
If they're already in A then just ignore the where clause
Code:
UPDATE [Table] SET ColA = ColB
and you are sure that you haven't already updated the table? That query will only work once.
My understanding is that you want you data to look like this?
Before:
ColumnA ColumnB
x y
x y
x y
After:
ColumnA ColumnB
y y
y y
y y
No error, just that no new rows are added.
UPDATE will not add new rows - it will update existing ones. I just tried this in mysql with a table with 10 rows, five of which had a != b:
UPDATE `colacolb` SET `cola`=`colb` WHERE `cola`<>`colb`
It fixed the five != rows without issue.
You guys are misunderstanding him and my SQL's slightly rusty.
He has the following:
A B
X X
Y Z
The output should be as follows:
A B
X X
Y Z
Z
A B
X X
Y Z
A B
X X
Y Z
Z
For this you can try
Insert into <Table> (<cola>)
Select Distinct <Colb> from <table>
where <ColB> NOT IN (SELECT <ColA> from <Table>)
INSERT INTO Test1(A)
SELECT Test1.B
FROM Test1
WHERE Test1.B
NOT IN
(SELECT Test1.A FROM Test1)
