Having read through the different threads on SSD's, I couldn't find clear advice on a few points I wanted to find out about:
1- Any particular motherboards that would work better with an SSD?
I bought the i5-2310 system PC Zone had on special, which comes with a MSI H61 Motherboard. This doesn't have any Sata 6gb/s ports, so I suppose I would need a better board.
They seem to have the following in stock, however others could be sourced:
Intel Bearup Lake H67
Intel Buffalo Flat P67
MSI Z68MA-G45
MSI X58 Pro LGA1366
2- Any SSD out there that can be classified as very reliable, not very expensive and offering good speeds?
I am probably going to get it from Newegg, with a friend bringing it to SA for me, so no customs, freight charges etc.
120gb should do, however priority would be to reliability, as sending it back if it fails would be difficult.
3- What is the Sandforce vs Indilinx controller debate about and which should I get?
4- Can I expect a significant difference in performance if I spend the extra R1500 to upgrade the i5 2310 to the i7 2600 or should that money be spend on the SSD?
MSI Z68MA-G45
MSI X58 Pro LGA1366
