Steering rack on BMW needs replacement
KSINGH
PTA
BMW-Part only R9000.00
Carnetics refurbishment of existing rack with new seals etc. R4500.00 . I must confirm warranty period with them.
Have any of you done a replacement or refurbishment recently? Where and how much? I got a e46 sedan.
Its better to go original for a nice rack.Used ones tend to hang a bit loose from the dash.
The used ones tend to droop a little lower than the average driving height ultimately ruining your steering pleasure.
a new one will be basically made of some metal and rubbers, pretty much the same way the old one will be refurbished so I dont follow you BOYAH.
How old is you car? Is it not still on motor plan or did you not take one?
A friend of mine had his gear box replaced recently on MP & didn't cost him.
There, as with car parts, I don't have the slightest issue with a decent refurb.
But it just doesn't drive the same.. And you can't help but worry if someone has driven harder than you before..
its 10 years old with 320 000 km on the clock. no MP.
yeah, theres no way i am gonna spend 9k for the part. labour will prolly be like 3-4k.
Sorry dude when i saw the word rack i got a bit naughty.Another option is to check the scrapyards as there will be tons of BMW parts for this model.If you can get one for a grand and have it refurbished and fitted yourself for another 2 grand thats will be quite a saving.I know a guy in Joburg who is a BMW expert that can help with parts- pm me if you're interested.
