Storm 2 9520 Low call volume
nazz
Gordons Bay, South Africa
I find that the call volume is too low. With the volume turned up to highest its still too low. I tried the audio enhancements etc etc with no luck.
It came with OS 5.0.0.306. I read on other forums that people were having the same issue after upgrading the OS. They didnt have this issue with older OS 4.x.
The call volume was fine on my 8310. Had to lower the volume a bit. Is anyone else having this issue with the Storm 2?
My volume is fine, was running 5.0.0.306 and updated to 5.0.0.341
So the upgrading does not affect your warranty? Was your call volume low before you upgraded? Did you also have breaking up of calls? I visited 2 vodashops and yhe said I can have mine swopped as a out of box fault. Now wtf about my invisibleshield that's been fitted? I'm gonna loose that almost R400. But I don't really want to re-use it on a new device as I don't think it will work properly.
