I know this is going to sound strange, but I am now flabbergasted and I have no idea where to turn to further.
I have used my iBurst modem without a problem up until now.
Used it on Windows XP, Windows Vista, with the Dashboard, without the Dashboard, with the Antenna, without the Antenna, it always works.
So currently, I'm using it on Vista SP1 32-bit, without the dashboard, without the antenna, connecting via USB.
Currently, I have a problem with the modem... switching off? As in, powering down.
The third status light (the orange one) goes off. Connection just drops. You cannot reconnect until you remove the USB cable and put it back in.
I've tried turning off the option for "Allow Windows to turn off this device to save power" under Device Manager for the iBurst Terminal. Not helping.
This happens while I'm playing DotA, surfing, downloading. In other words, it always happens.
Second reason why I believe it could be something Windows related... it always seems to happen... just about an hour after a connection.
I've checked the "Never" option under disconnect, etc, etc, etc.
What else could it be?!?
Didn't have these problems on my XP computer...
EDIT: Forgot to mention that I do have a Lenovo T500 laptop... laptops and power saving settings still confuse me a bit. I tried switching off as much as I could, but I could be missing something?
