Since last week my laptop when plugged in shows "plugged in, not charging" when I'm at home. Then I go to work it does charge the battery and shows charging.
New batteryBattery showing signs of aging
I think the laptop is not getting enough juice to do both charging and powering the machine so it only powers the machine. Something with this house's electricity setupSilly question - have you checked the wall plug at home?
Could be the circuit is overloaded?
Yes it is a Dell laptop. Other devices work fine on that power point.Is that it a Dell? Had this with about 10 machines, had to replace powersupplies. Dell replaced thos under warranty
yes. battery is newDo you use the same charger for home and work?
