Strange Router Startup Problem
DollyAAAA
Durbanville
Hi All!
I have a strange problem on my Telkom (Marconi) WiFi ADSL Router. (Yes I know...) When powering it up together with the device on the other end of the LAN connection, It works for a while, and then goes in to "chatter mode". The LAN LED starts flickering insanely and no data flows. Power-cycling the Router solves the problem, until the next power failure. It does not matter what is on the other side, could be PC or other router. There is also no firmware upgrade available for this sucker.
I was just wondering if someone else had this problem, and maybe has a fix for it.
Thank you!
