Hey all,
I just need some help on finding a few items for a serious overclocking session, been digging for a while and I would like some further insight before making my final decisions. Suggestions, comments, questions welcome.
I have a home-made phase change cooler (got my 8400 wolfdale 3GHz to boot at 6GHz and run stable at 5) and a home-made water chiller that can hold 2 dual-core opteron 286's at sub-zero temps running at full load, indefinitely. I now want to apply both of these to a gaming rig but due to the low temps over so many locations on the board insulation has become a nightmare. I intend to use the phase on the CPU while the water chiller will be routed to my GTX 260 CPU waterblock, NB waterblock, and MOSFETS waterblocks if I use my asus striker II formula over my P5Q-Deluxe. The idea is to submerge the motherboard in mineral oil to negate the problem of condensation, the transfer will also cool the mineral oil, dropping the ambient temp of the board.
I'm looking for:
-Store to get Tygon Suitable for sub-zero application, in South Africa
I've used high standard garden hose on my last rig with a standard plexi pump for antifreeze at -23 degrees Celsius.. I'm just glad I took it apart before the inevitable happened.
-Mineral oil suitable for submerging my motherboard ***bit off topic of forum I suppose but doesn't hurt to ask
i.e.: no electrical conductivity, a high flashpoint and not too aggressive on component materials
-Suggestions on a stylish cooler box to house the motherboard in the mineral oil (The math I'll do myself, just can't find any I like)
I'm battling to find one that is an appropriate size, they're either way to small, way too big or just too ugly. The smaller it is the lower the 'ambient' temp should get, but the capacity will be fairly low... for overclocking the lower the temp the better but if the capacity is too low that affects how long the required temp can be sustained.
Cheers,
Arky
I'm looking for:
Cheers,
Arky
