Hi all
First time poster and solar power user here.
I have recently had a sunsynk 8kw inverter installed with 18 455w panels and a solar md battery (7.4kwh). From all the research I've done, it appears that the battery does not have comms with the inverter so it is currently discharging, charging, measuring SoC etc based on voltages (despite being connected via canbus). Does anyone have any experience with this? The generally accepted solution is to use the solar md logger but based on other threads, it isn't the most reliable ( and it's just under R5k)
The other problem I'm facing is the time of use settings are based on voltage as opposed to % which is more complex than i would have preferred.
Will appreciate any insight
