Heisenborg
- Dec 15, 2006
That screen does not show that there is no voltage on MPPT2. What is does show is that MPPT2 is producing no power and MPPT1 is producing very little power. The likely cause is that there is no current on MPPT2 while the voltage will be close to the VOC of the string.Hi all
Noticed today that there was no voltage from mppt2 on my 8kw sunsynk.
Would a system reboot help and what are the steps?
Hi. Pic was taken at 5pm or so.That screen does not show that there is no voltage on MPPT2. What is does show is that MPPT2 is producing no power and MPPT1 is producing very little power. The likely cause is that there is no current on MPPT2 while the voltage will be close to the VOC of the string.
There is to little information to determine if something is wrong, but my guess is that what you are seeing is caused by low irrandiance (no direct sunlight on the panels very early in the day or late afternoon).
Are you worried that the two string are producing different power? This is pretty normal
Is it rated correctly?Turns out the fuse was blown on mppt2. 2min job to fix
Installer did the work. So im gonna go with yes?Is it rated correctly?
Without checking? OK if you think he'll get it right second time around.Installer did the work. So im gonna go with yes?
Remember a fused does not blow by itself.Turns out the fuse was blown on mppt2. 2min job to fix
