ocky
Only those in the main repo. not in universe for example. Some supported for only 9 months.
Check it.
ubuntu-support-status --show-all | less
On my Kubuntu 14.04 (with purported 5 yr. support) ..
You have 128 packages (5.4%) supported until February 2015 (9m)
You have 4 packages (0.2%) supported until January 2017 (9m)
You have 115 packages (4.9%) supported until May 2017 (3y)
You have 1961 packages (83.3%) supported until May 2019 (5y)
<SNIP>
Good idea to run a sandbox. Firejail is easy to use. Give it a go.
https://firejail.wordpress.com/
Check it.
<SNIP>
