Synapse 3.0 Inverter with Hubble AM-2 Battery settings - error code 8
IamGavZA
Hello,
Could someone pls assist in listing all the correct settings for the Hubble AM-2 battery for the Synapse 3.0 inverter?
I’m getting an error 8 code, which is “bus voltage is too high”.
Below is an image of the AM-2 battery settings, which has been inputted into the synapse 3.0.
The inverter functions normally during load shedding but once the battery reaches full charge the inverter trips with the error 8 code.
What setting should be used below?
Should it match the above float setting of 29v?
Old thread, but I have the exact same issue. Did you ever manage to solve this?
Same issue now that LS is back, having not used the inverter/batteries properly for 20 months. Was never an issue in the past...
Synapse 3.0+ with 2x Hubble S120
