Jonny Two Shoes
Hi all,
Once again one of my users has a particularly annoying problem.
For the sake of her being able to work at home I have synchronised a particular folder off the fileserver for her. All worked fine and dandy until one day it suddenly went haywire.
Once before I had to take away "make available offline" and then enable it again as it didn't want to sync. This fixed the problem for a long while.
Now suddenly the problem is back and just does not want to go away no matter what I try.
Everytime the user comes back to work and plugs her laptop into the network and logs in it does not want to sync with the changes she made to the offline files. I see it says "the parameter is incorrect" as part of the error however I dont understand how this can be as the moment I take sync away and re-apply it there are no parameter issues until the next day!!
Can anyone here suggest general solutions with this type of sync problem? She is using win XP with all updates pushed by Corporate.
