Syntax Help. C# , ASP.net
Pho3nix
The Legend
On the toilet
Code:
 var ExternalPackageData = (from Package in externalPackageData where (Package.FieldValues.ElementAt(3).ToString = strGuid)
                                       select new
                                           TaskUID = Package.FieldValues.ElementAt(1).Value.ToString(),
                                           ProjectUID = Package.FieldValues.ElementAt(3).Value.ToString(),
                                           PackageName = Package.FieldValues.ElementAt(4).Value.ToString()
                                       }).ToList();
Keep getting an error on the Where part..assistance?
Package.FieldValues.ElementAt(3).ToString()
:o Thank you..moomish of note.
How would I handle null values as they crash the application?
You'll have to check if values are null and handle that, ie:
if(myItem == null)
// set it to not be null or display warning
Code:
var ExternalPackageData = (from Package in externalPackage where(Package.FieldValues.ElementAt(4).Value != null)
Went with this..but soon found out that it really wasn't working because the SQL server had been shutdown for some reason..
Thanks for all the help
You should ask these kind of question at StackOverflow, much more answers in a shorter period of time
