Tablet as remote control - Charging
Dolby
I've seen a few cheap tablets I can use as a remote control - but anyone know a model with a docking station / wireless charging?
I tried the app on 3 Android devices and both with Android 6 failed - so maybe something before 5
You not going to find the cheapies with docking station, however, you may find generic docking stations, i am not sure.
I have just advertised a Proline Tablet for sale, you may check it out. Specs are on par, or slightly better than cheapies you may find for around the same price.
Proline 9.7" Tablet - 16GB
Technical Specifications
Operating System: Android 4.1 (Jelly Bean)
Processor: Cortex A9 1.6GHz (Dual Core)
Memory: 1GB Memory
Hard Drive: 16GB
Screen Size: 9.7" IPS 10 Point Touch
Recommended Resolution:1024 x 728
WiFi: 802.11b/g/n
Speakers Yes
Microphone Yes
Front Camera 0.3MP
Rear Camera 2.0MP
Battery 3000mAh
Ports
Micro USB Connectivity
3.5mm, Headphone
Micro SD
Mini HDMI
Dimension (LxWxH) 242 x 189 x 10mm
Box and all accesories included.
Check Link and retail price below:
http://www.loot.co.za/product/proli...eCheck&utm_medium=Web&utm_campaign=PriceCheck
Thanks.
I've got at tablet but too large at 10.1"
It's got a docking station but was hoping for something similar at 7" or so
You need a tablet with an ir blaster in order to use it as a remote for example most LG tablets have one.
I have a IR blaster.
But I'm using an app on WiFi, so it works. My current tablet is too large and on Android 6.0 (app doesn't seem to work - unless anyone else on 6.0 wants to try it out?)
So I want to go smaller, older version of Android - but I don't want to plug it in everytime. A dock, or charger, or wireless charging seems far better
Let us know if you find anything suitable. I'm quite interested in purchasing something like this myself.
What app are you using.
I was using RemoDroid but since the update it doesn't work anymore.
Called Logitech Squeezebox Controller.
I have a Squeezebox running Tidal and use a phone to control it right now.
