Targa Street Falcon power
PurpleSnow
Krugersdorp
Good day
is ther anyone that can help me woth a street falcom 40k
Im having trouble with keeping it over 12v when playing.
it drops so low and draws power from other amp then both go into protection
What rating is your flux capacitor? I think you may need a higher-rating to support both.
Good day
bigger cables ,another battery, 2 of 1 farad capacitors and a 120 amp alternator
But now, when you get to that level, isn't it better to ask on car audio forums?
it wont help just asking its going to be a full new install with a proper targa wiring kit for that amp just the wiring kit for that amp is 1k ,most just use the generic china shop kits and they dont work ,its a start from scratch ordeal ,that amp can pull 100amps up too 233amps at peak at full throttle not a nice scenario .
extra battt done car has 120a alternator standard.
was wondering if the cable was getting a bit old had it for a while already. 4th car it has been in.
while system was perfect in previous car.
