Television Help Pls!
Slig
Hi guys,
I got this TV for my birthday http://www.houseandhome.co.za/index.php/audio-visual/television-by-type/hisense-49k3110pw-125cm-s-fhd-led-tv-b.html
But was wondering if it would be better to change it for more reputable brand.
These would be my options within my budget:
1) http://www.houseandhome.co.za/index.php/audio-visual/television-by-type/lg-49lh510v-124cm-fhd-led-tv-b.html
2) http://www.houseandhome.co.za/index.php/audio-visual/television-by-type/panasonic-th-49d330q-125cm-fhd-led-tv-b.html
Would be used for gaming and lots of movie watching. Not really sure I need a smart TV function.
You will look far to find a better TV than the Hisense. Go do a comparison at Makro and see for yourself.
Change it only if you want to go for UHD. The go for Hisense UHD 7000 series.
Hi guys,
What's wrong with Hisense?
They have amazing guarantees :)
Kloppers in PE have a HiSense 49" Full HD Smart LED Model 49K3110PW for R5999. Is this a good buy?
Hi guys,
Ask MYBB to test those models for you to check if they are definitely FHD TVs! See the threads about fake FHD TVs doing the rounds.
