Telkom 5100 router / 2 accounts help
adsl3g
Pretoria
Can anyone assist in setting up 2 accounts on the Telkom 5100 router -
I try and set up 2 profiles (no 1 being my SAIX info) but when I select profile 2, I do not get the option of setting the IP address to be obtained automatically - I have to insert an IP address.
I have put the IS settings under profile 1 and it is working fine but I would like to switch between the two by activating and deactivating either profile 1 or 2 whichever one I need to use.
Is this a bug in the firmware - I am sure someone must have set it up like this on the forums. My other option is to install my Plane router but that thing has millions of settings just for WAN.
bekdik said:
Try using ppoe on the client machine.
Thanks - but I want the router to do the connection as I run a wireless network at home. I connected my Planet router and it is working fine - still want the Telkom 5100 up though.
