Telkom Easy Connect Fibre
jeppe777
Durban
  • 20Mbps Uncapped - 200GByte - throttle to 20% of line speed during 18h00-23h00 peak hours
Does the throttling happen daily during this time or only after you exceed the 200gb?
Quick question. Why are you considering Telkom easy connect?
It's for granny
Why not go for webconnect directly? Its about the same price. Same setup with an all in one ont not fair use policies.
If you don't want that then just go for the prepaid or prepaid monthly option on the app? 30 days free and not setup and activation like the easy connect one which is very expensive with setup and install.
