Have a friend in constantia CT. After entering ISP details, all works fine although internet speed fluctuates dramatically. After a couple of days the router has lost the ISP settings. Installed second router and exactly the same thing happens, works fine, few days later, router lost settings..
What can this be?
Looking at the ISP sessions, the connection is very unstable, keeps resetting every few minutes..but can this cause the router to reset?
Going to change the pots filter and see if that helps.
Any other thoughts?
Last resort would be to get telkom to check the lines properly. But still confused as to how a faulty line can reset the routers?...
What can this be?
Any other thoughts?
