Telkom line speed specification
Superjakes
Centurion
Is anybody aware of the Telkom line speed specs changing? I logged a call with them earlier this week, as my 4Mbps line was only syncing at 3327Kbps down and 508 Kbps up. Just got a call from a consultant, saying "you have to add the two together to get to the 4Mbps, so the speed is right". As far as I had it - it was 4096Kbps down and 512 Kbps up all along. It has also been working fine at that speed until about a month or two ago.
Does anybody have a link to the specs? The Telkom website is very marketing related "fast, faster and fasted" instead of real numbers.
That is exactly what I told her. I have been a DSL customer for 10+ years. Did get her name, though...
Maximum DSL line synch speeds:
DSL Up to 2048kbps
Down stream: 2048kbps
Up stream: max 512kbps
DSL Up to 4096kbps
Down stream: 4096kbps
Up stream: 512kbps
DSL Up to 10016kbps
Down stream: 10016bps
Up stream: 1024kbps
DSL Up to 20Mbps (VDSL)
Down stream: 20Mbps
Up stream: 2Mbps
DSL Up to 40Mbps (VDSL)
Down stream: 40Mbps
Up stream: 3Mbps
DSL Up to 2048kbps
DSL Up to 4096kbps
Up stream: 512kbps
DSL Up to 10016kbps
Up stream: 1024kbps
Down stream: 20Mbps
Up stream: 2Mbps
Down stream: 40Mbps
Up stream: 3Mbps
If you are on 20Mbps VDSL with interleaved mode then the download sync speed is 22.5Mbps.
