Not sure but you can have a look here:
elinux .org/RPi_USB_Wi-Fi_
Adapters
I got the TP-Link TL -WN725N nano adaptor for around R120 from takealot (If you order off the Mobile App you get free delivery under R250 order). Took a while to get it working, but can now do it in a few Minutes. IIRC I followed this tutorial:
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=62371&sid=0339a5df6181a6475ff3a13b75fbdbd1
Check the first post. Basically you check what version of linux you have. Then check what file that corresponds with. Download that as per the instructions. If you cant connect with a ethernet cable put the file on a flash drive and copy to R-Pi. Unzip the file. Change to root. Change permission of of shell script
https://www.raspberrypi.org/documentation/linux/usage/commands.md
. Run shell script. Should tell you that you must restart.
Bought the Edimax from RS Components and works out of the box.
Adapters
